Aug 17th, 2024, 5:24pm
problem with LO square and LO sinsoid (Read 3889 times)
James Bond
Aug 10th, 2007, 2:26pm
Hi, all,
I met a strange problem. When I did the simulation for the passive mixer, I apply a LO square signal to the switches of the mixer, it works fine, two of the switches are in linear region and others are off. But when I apply a sinsoid signal , it didn't work, all the switches are off. Has anybody met this problem before? Any idea would be appreciated.
Thank you very much.
James
aaron_do
Re: problem with LO square and LO sinsoid
Reply #1 - Aug 11th, 2007, 8:33pm
Its probably a problem with your DC biasing. It should work with sine wave.
James Bond
Reply #2 - Aug 12th, 2007, 12:07am
Hi, aaron_do,
I have tried both way:
1. No bias for the passive mixer, I use ideal LO square, 600mVpp, it's working, but when I changed to LO sinusoid with the same amplitude , it didn't work.
2. If I have a 300mV bias to the gate of all the switches, applying a 300mVpp LO square,  it's still working. but when I changed to LO sinusoid with the same amplitude, it didn't work.
It's quite wiried I think, is it possible that maybe some settings in the spectreRF or some properties of model will affect this ?
aaron_do
Reply #3 - Aug 12th, 2007, 4:30am
hmm...that's strange. What simulation are you running? I would check the DC bias points of all the nodes and also check the LO amplitude at the mixer gate to make sure there's actually an LO signal...
cheers,
Aaron
James Bond
Reply #4 - Aug 12th, 2007, 9:03am
HI,
Let's say we have a 300mV dc  bias applied to all the gate of the switches, and sinusoid LO+ amplitude is 300mVpk to one of the pair, and LO- has 300mVpk to the other pair. Then the dc simulation is run.
I check the dc operating point, all the switches have the Vgs = 300mV, Vds = 0, Vth= 569mV, actuall, the amplitude of sinusoid didn't add to the gate voltage. The 'region' is 0, this is also very strange, at least it should be region 3(weak inversion) I think.
aaron_do
Reply #5 - Aug 13th, 2007, 1:38am
Hi James,
I don't really know what's wrong but i can tell you i've never had a problem simulating a passive mixer with sinusoid LO. I usually set the DC bias voltage to be around 450 - 500 mV where vth is around 480 mV.
Aaron
