Aug 16th, 2024, 7:36pm
error "quantity exceeds blowup limit 1G (e9)" (Read 6521 times)
babuchacko
Aug 15th, 2007, 12:11pm
I am creating a transistor model, in vhdl ams which consist of several simultaneous equations. At one point in the model i need to determin a quantity which takes a value of the order e16 when i calculated manually....
the simulator gives an error which says "the quantity exceeds blow up limit  e9(1G)".... though it make sence for the error, i need to include that quantity which attains a value of the order e14... how can i overcome this prb.. can anyone help me......
thankyou
Babu chacko
adauto6
Re: error "quantity exceeds blowup limit 1G (e9)"
Reply #1 - Aug 15th, 2007, 1:41pm
Maybe you have to set other tolerance for that quantity ...
babuchacko
Reply #2 - Aug 15th, 2007, 3:21pm
thank dude...but I have never tried changing the tolerence limit of a quantity...Do anyone know how to do that??
ACWWong
Oxford, UK
Reply #3 - Aug 16th, 2007, 3:48am
in verilogams you can use the nature declaration. an example is:
nature Frequency
    abstol = 1K;
    access = FF;
    units = "Hz";
    blowup = 1T;
endnature
perhaps you can lookup in your vhdlams manual something similar.
babuchacko
Reply #4 - Aug 16th, 2007, 6:33am
thanks for the suggestion.... will try that one....
Reply #5 - Aug 17th, 2007, 4:45am
Strange -- are you outputting that quantity?  Verilog-AMS simulators don't generally care what you do with the internal variables and only complain when terminal voltages and currents exceed blow-up limits.
You could also re-scale the quantity, ie, factor out 1e10 in the computation and put it back when you use the quantity.
