Sep 16th, 2026, 5:28am
oscillator (Read 2012 times)
kamath
oscillator
Aug 16th, 2007, 3:27am
i am designing period-controlled-oscillator,but not getting the desired output from block.please suggest any changes to be made
module myosc(in,out,clk);
input in,clk;
output out;
electrical in,out,clk;
parameter real vh=1.5;
parameter real vl=0;
parameter real vtrans=0.6;
parameter real maxp=(1/5000000);
parameter real minp=(1/500);
integer comp;
integer n;
real period;
real step;
analog begin
@(initial_step)begin
period=(1/500000);
step=(1/5000) + $abstime;
@(timer(step))begin
n=!n;
step=step+(0.5*period);
@(cross(V(clk)-vtrans,1))
begin
if((V(in)-vtrans)>0)
comp=1;
else
comp=-1;
period = period +(comp*step);
if(period>maxp)
period=maxp;
if(period<minp)
period=minp;
V(out)<+transition(n?vh:vl,0,100p);
Re: oscillator
Reply #1 - Aug 16th, 2007, 7:05am
kamath wrote on Aug 16th, 2007, 3:27am:
period=(1/500000);
1) Why $abstime?  Won't it always be 0 when initial_step occurs?
2) the step is much larger than the period (step = 200u, period = 2u), so the timer(step) will let 100 periods elapse ...
