Croaker,
One other thought, can you design around the problem at a higher level of the system? For example, in an integrated switched-current DAC, you can use the resistor-type for the reference current generator and the DAC load resistors. Then the error is reduced to the mismatch between the resistors. Since the resistors values will track across process, voltage, and temperature, the overall system looks like it has absolute accuracy without actually using precision components.
