Aug 15th, 2024, 7:30am
Convergence problem in system level sim. of DCR (Read 2335 times)
eng
USA
Aug 16th, 2007, 12:41pm
I'm simulating a direct conversion receiver consists of LNA, Mixer, Pre AMp, LPF and Limiting Amp. I used PSS PXF PNoise to see overal gain and NF. However the PSS simulation does not converge. I was using Moderate as tolerance, I changed it to libarel and conservative but both gave same convergence problem. Can you please suggest what else I can do?
eng
Re: Convergence problem in system level sim. of DC
Reply #1 - Aug 27th, 2007, 10:04pm
Read the suggestions it gives you when it doesn't converge, and read the documentation. It's hard to answer without more information... there are potentially ots of things that could cause convergence failure.
