Jeffery,
Sorry happy fingers:
3) Design of the bypass network a) Location of the bypass capacitors: on-chip or off-chip b) For off-chip capacitors, the type of capacitors used different capacitors have different characteteritics, ESR, ESL, ... c) For on-chip capacitors, use device models do not use ideal capacitors, for example, a MOS gate capacitor value is bias dependent 2) one other thing I forgot, f) include the effect of the on-chip power supply routing
The list is fairly exhaustive and not all effects need to be included, but, what needs to be included is design specific. You need to think carefully about what you are trying to simulate and build a model for the power supply distribution systems that accurately reflects the implementation.
