Aug 15th, 2024, 6:01pm
passing parameters from verilog-a  to ADE (Read 3111 times)
just started
usa
Aug 21st, 2007, 9:08pm
Hi
I am working with a verilog-a code. I wish to be able to pass one of the parameters in that code to
ADE. Maybe I am supposed to create a paramter by that name in the CDF or something...
cannot find any suitable link that can help...if anyone knows please tell me...
Re: passing parameters from verilog-a  to ADE
Reply #1 - Aug 23rd, 2007, 6:03am
just started wrote on Aug 21st, 2007, 9:08pm:
Hi
Pass a parameter from Verilog-A to ADE?  That sounds backwards.  Do you mean, you want to be able to set a parameter for an instance that is modeled with Verilog-A?  Creating the CDF parameter would be a good start; I don't know if your netlister needs some changes, too.
just started
usa
Reply #2 - Aug 23rd, 2007, 8:08am
Actually I did get it...created a output voltage node in the code...passed the parameter to that node and passed that node to ADE...i wish to run monte carlo on that parameter...
