HdrChopper
In addition to Sheldon comments, I'd like to add the following:
- The input of your CMFB circuit is tied to the middle point of the sensing resistors and also to the drain of the NMOS active load (at the right). This is not good since you are heavily reducing the common mode gain of your circuit (by reducing the impedance at that node) and also unbalancing such circuit, since the current that should flow through the active load is the one comming from Vbias current source / 2. Finally, your differential circuit would be heavily loaded (on top of the 1K sensing resistors load, which I agree sound like too small), may be too much for what is intended to drive (may be this is the reason why you are getting too small dc gain).
- I cannot see in your schematic where the CM feedback signal is applied! If you are trying to control the output CM level by just forcing the connection of the middle point I mentioned above, I do not think that will work and actually it would not be a CM FEEDBACK circuit. What it is usually done in this case is generate Vbias4 from the gate voltage of the CMFB active load, assuming the correct sizing and current levels for these devices.
Regards Tosei
