Sep 19th, 2026, 5:07pm
constant reference loading MDAC (Read 4470 times)
vivkr
Aug 30th, 2007, 6:10am
I am looking for a constant reference loading MDAC structure because of  problems with the conventional 1.5-bit MDAC (Please see attached PS).
I am assuming a fully differential arrangement.
If you look carefully, the amplification phase involves connecting the bottom-plate of CS to either +/- VREF or AGND (Common mode reference).
This implies that the load seen by the reference is code-dependent. This can be fixed with dummy cap banks. The more serious problem is that this is a 3-point DAC,
which is not guaranteed to be inherently linear. Any offset on the differential reference levels +/- VREF will show up as DNL.
I considered use of a scheme similar to the one given in the TCAS-II (May 2004 paper) by Yoo, Park, Moon where CS would be split into 2 halves
CS1 and CS2. Now, for +/-VREF, one could connect both halves to either reference, while for providing 0V DAC voltage, you would now
connect CS1 to +VREF and CS2 to -VREF. Thus, only a 2-point DAC is used which is fundamentally linear.
http://web.engr.oregonstate.edu/~moon/research/files/cas2_may_04.pdf
However, this scheme is not symmetric and will result in increased distortion for very small inputs close to zero. This is often a requirement.
Can anyone suggest a scheme which would avoid the problem of having to use a 3-point DAC but which would give good linearity at low signal levels?
Vivek
vivkr
Re: constant reference loading MDAC
Reply #1 - Sep 4th, 2007, 4:20am
Looks like the topic interested nobody. Perhaps I should have not forgotten to add "pipelined ADC" in the title.
Anyway, I did not find any convincing solution for this problem, although I saw some people who use 2 separate
capacitors, one for feeding the input, and one for feeding the DAC feedback. The idea is to increase the number of caps
connected from +VREF/-VREF to the summing node as the DAC code increases. This way, nothing is connected at all
to realize 0 DAC feedback.
However, it is not obvious whether this method does not have a hidden trap which causes the same problems as I mentioned.
It will also have the additional burden of varying feedback factors for the opamp and slightly nonoptimal compensation
as a result. It will also have more noise in general as more caps are connected to the OTA although the net input charge is the
same.
Vivek
Reply #2 - Sep 8th, 2007, 7:04pm
Hi Vivek,
Sure I am interested in your topic.  :)
Here I have one question. Normaly I short the bottom-plate of CS if the code decide to connect to AGND. So I don't think that an offset on the differential reference levels +/- VREF will show up as DNL. Am I right?
Best regards,
Yawei
vivkr
Reply #3 - Sep 17th, 2007, 1:40am
Hi Yawei,
Won't it? I was thinking about it but maybe I thought too much and got it all wrong. If you look at the 1.5b MDAC (say).
Now, in the middle segment, Vo = 2*Vin, you connect the bottom plate of CS to AGND. In the top segment to +VR, in the
bottom segment to -VR.
If the differential voltages +/-VR have an offset to AGND of voff, then the step transition going from the middle region to the
side will be changed by this. Normally, you should have a step height of +VR in each case (assuming +/-VR reference).
But it will be now VR +/- voff. This change is equivalent to having some DNL in there, isn't it?
Vivek
vivkr
Reply #4 - Sep 17th, 2007, 3:09am
Hi Yawei,
If you think that the MDAC is always trying to realize Vout = 2*Vin - Vdac, then you can see the problem.
Normally, Vdac should take values { -VR, 0, +VR } . This is a linear 3-point DAC, but if there is an offset voff on AGND, then you realize
{ -VR, voff, +VR }. This is now a nonlinear 3-point DAC, and there seems no way of fixing it in this form.
What do you say?
Vivek
