Aug 15th, 2024, 6:37pm
syntax error about the comparator (Read 3116 times)
James Bond
Sep 02nd, 2007, 12:36am
Hi, all,
I wrote the veriloga code for the comparator, but when I compiled this code, it reported:
"@cross(<<--? V(insin) - V(intri),0)",  Does anybody know where is the problem ?
My code is like this:
`include "constants.vams"
`include "disciplines.vams"
module comparator3(cout, intri, insin);
output cout;
input intri,insin;
electrical cout,intri,insin;
parameter real td = 1n,tr = 1n,tf = 1n;
analog begin
  @cross(V(insin) - V(intri),0)
     V(cout) <+ transition((V(insin) > V(intri)) ? 1:0,td,tr,tf);
Please give me some instructions, thank you very much.
James
Re: syntax error about the comparator
Reply #1 - Sep 2nd, 2007, 1:00am
I believe you need the argument to the @ statement to be within parentheses.
@(cross(...))
rather than
@cross(...)
In addition, you cannot have a transition function, or a contribution operator, in the body of an event statement.  Instead you probably want something like the following ...
analog begin
   @(cross(V(insin) - V(intri), 0)
   V(cout) <+ transition(V(insin) > V(intri), td, tr, tf);
James Bond
Reply #2 - Sep 2nd, 2007, 7:37am
Hi, Ken,
Thank you so much. Now it is working. I would like to ask you another question about this model.
Now the V(cout) is 1V, but my supply is 2V, how can I program to make it reach  the full swing supply ?
or maybe, since my input signal intri and insin are not ideal signal, they all have a dc bias about 1V, how can I make my comparator output have a 1V dc , the it will reach 2V swing, I think.
Thank you very much
Best Regards
James
Reply #3 - Sep 2nd, 2007, 2:18pm
To adjust the output voltage to 2V use ...
   V(cout) <+ 2*transition(V(insin) > V(intri), td, tr, tf);
With that the output will swing between 0 and 2v. If you want the output to swing between two arbitrary voltages use ...
   parameter real vl = 0;
   parameter real vh = 2;
   V(cout) <+ transition(V(insin) > V(intri) ? vh : vl, td, tr, tf);
James Bond
Reply #4 - Sep 3rd, 2007, 10:43am
Thank you very much. It's working
Best Regards
James
