Aug 15th, 2024, 1:29pm
Pnoise in Time-Interleaved Circuits (Read 3104 times)
Friedel
CA
Sep 04th, 2007, 12:16pm
Hey Guys,
I use the Pnoise analysis to verify the noise performance of a sample-hold block.
The SH uses a clock frequency of 200MHz. From the strobed Pnoise analysis I got the noise power density V^2/Hz
with I integrate up to 100Mhz to get the noise power.
The obtained value is close to the expected kT/C value.  :)
(thanks all for the help in the past on this topic!!)
The total input stage consists of two time-interleaved SH blocks.
each operating at 200MSs. Thus the total input bandwith is 200Mhz!
Over which bandwidth I have to integarte the  noise power density V^2/Hz
if I simulate both SH stages operating in a ping-pong (interleaved) fashion?  :-[
Still 100Mhz since each stage converts only 100Mhz?
Frank Wiedmann
Munich, Germany
Re: Pnoise in Time-Interleaved Circuits
Reply #1 - Sep 4th, 2007, 11:40pm
You always have to integrate to half the frequency specified in the pss analysis setup.
Friedel
CA
Reply #2 - Sep 5th, 2007, 11:21am
Frank,
I agree.
Only to be sure, that my approach is correct:
I use a 400Mhz clock (->beat fre=400MHz). The clock is feed into a divider
generating 2x200MHz clocks shifted by 180deg.
Since my beat frequency is 400Mhz, I have
to integrate over 200Mhz each SH output?
But each SH is only sampled at 200MHz? Undecided
What would be your approach to simulated such a circuit correctly
(an easy way to evaluate the noise perfromance of an time interleaved circuit?)
Thanks much
Friedel
Frank Wiedmann
Munich, Germany
Reply #3 - Sep 6th, 2007, 12:25am
All signals in a pss analysis must be periodic, so you have to set the pss frequency to the lowest frequency that occurs in your circuit, which is 200 MHz, not 400 MHz. I would be very surprised if your pss analysis converged at all when you set the pss frequency to 400 MHz.
