Aug 17th, 2024, 6:17am
How to sim opamp's input referred system offset? (Read 4715 times)
pipeline
Sep 13th, 2007, 9:32am
Could system offset be determined by simulation? Or just by analysis and hand calculation? Is Monte-Carlo simulation only suitable for random offset?  :-/I'm confused about these questions. Would any one kindly elaborate them? Thanks very much.
learning to walk on the road of analog
Berti
Re: How to sim opamp's input referred system offse
Reply #1 - Sep 13th, 2007, 10:39pm
Systematic offset is caused either by asymmetrical circuits or layout. It is therefore
straight-forward to simulate systematic offset with a circuit simulator(using post-layout
back-annotation, respectively).
For random offset you can use monte-carlo simulation assuming your design-kit provides
you with statistical data.
To simulate offset you should therefore add asymmetrics from the layout into your
schematic (at least parasitics, PWE and STI is only required for 130nm and below)
and run a monte-carlo simulation using the statistical data provided by the fab.
pipeline
Re: How to sim opamp's input referred system offset?
Reply #2 - Jun 20th, 2009, 8:24pm
Clear! Thank you very much!
raja.cedt
Reply #3 - Jun 21st, 2009, 12:53am
hi berti,
         i have one doubt in systematic offset, lets say i have an opamp with output biased at 1v and assume now i have connected opamp in unity gain configuration and gave .7 as input, so now offset is .3/(open loop gain) ..is this systematic offset?
Rajasekhar.
HdrChopper
Reply #4 - Jun 22nd, 2009, 9:36am
raja.cedt wrote on Jun 21st, 2009, 12:53am:
hi berti,
Hi Rajasekhar,
That is not a realistic scenario: since the opamp is in closed loop, the input referred offset is equal to the ouput offset / closed loop gain; assuming sufficiently large open loop gain. Therefore 0.7v input referred offset means 0.7v output referred offset, although obviously .
these are not realistic offset magnitudes.
Tosei
Keep it simple
aaron_do
Reply #5 - Jun 24th, 2009, 6:03pm
Hi Raja,
if you have an op-amp in unity gain configuration, the output should follow the input. So how do you "bias" the output at 1V?
cheers,
Aaron
