Aug 15th, 2024, 12:28pm
SpectraVerilog sim: Glitch on AD/DA interface (Read 2029 times)
neoflash
Mixed-Signal
Designer
Sep 14th, 2007, 6:20am
Hi, folks:
I do have a trouble with simulation with Spectra_Verilog. The problem is that there is often a lot of glitches on the interface signals between analog and digital. If the signal is a clock, it will incur double trigger.
How to entirely solve this problem?
Re: SpectraVerilog sim: Glitch on AD/DA interface
Reply #1 - Sep 16th, 2007, 9:29am
Neo_Flash,
  It might be good to talk to your support AE.
Questions and comments:
1) Which version of Spectre are you using?
   In more recent versions of Spectre should have better accuracy
2) What errpreset are you using?
   If you are doing something that requires a lot of accuracy, for
   example, simulation of an analog/digital feedback loop, then
   tighter accuracy control may help. In the past, using the Spectre
   transient option relref=pointlocal helped me for one tough circuit
3) Try AMS Designer if you have access to it
