Aug 16th, 2024, 2:26am
VCO pulling, (Read 6354 times)
aaron_do
VCO pulling,
Sep 16th, 2007, 8:10pm
just wondering, how big of a problem is VCO pulling? I have a receiver which uses a direct conversion transmitter, and furthermore, the PA is not ON in receive mode. Therefore, i'm thinking that VCO pulling will not be a big issue.
cheers,
Aaron
hmm......seems direct conversion transmitters have a worse VCO pulling problem...
Aigneryu
Re: VCO pulling,
Reply #1 - Sep 16th, 2007, 9:47pm
 When your transmitter is on, the output of PA will be a carrier-modulated signal, which will be different from your VCO. So if you have some feedback path, the PA will still pull your VCO. So that is why the VCO frequency should avoid to be the same as your LO in a "integrated" "direct-conversion" (or low-IF). If you lock your VCO at 2x of the required LO, then you can prevent the pulling.
Sincerely,
aaron_do
Re: VCO pulling,
Reply #2 - Sep 17th, 2007, 6:27pm
thanks for the reply,
one thing though, if we have a direct conversion transmitter and the modulated signal is symmetric about 0 Hz, the upconverted signal will also be symmetric about the LO. So therefore, can we expect much pulling effect. i.e. which way would it pull?
thanks,
Aaron
nxing
God help the person
who help themselves
China
Re: VCO pulling,
Reply #3 - Sep 19th, 2007, 4:20pm
It really depends on how strong your PA output and how linear it is. 2X LO is not necessary enough to prevent the pulling. THat's why some companies use 4X VCO or 3 X VCO.
aaron_do
Re: VCO pulling,
Reply #4 - Sep 19th, 2007, 6:34pm
thanks for the advice  :)
I was quoting from memory, but i guess i was quite far off.
Aaron
yang
Re: VCO pulling,
Reply #5 - Sep 20th, 2007, 6:55am
Aigneryu wrote on Sep 16th, 2007, 9:47pm:
Sincerely,
Hi Aigneryu,
Could you please give us some examples of " So if you have some feedback path"? In my experience, the common VCC and Ground maybe a feedback path.
Best regards,
Yang
View Profile yang   IP Logged
