Aug 15th, 2024, 11:01am
Optimization in Eldo (Read 3041 times)
Mooraka
Lexington, KY
Sep 19th, 2007, 9:12pm
Does Eldo or Hspice has optimization capability to meet goals at different temperatures?.
AD
Mooraka
Lexington, KY
Re: Optimization in Eldo
Reply #1 - Oct 27th, 2009, 8:14pm
Here is the solution I found for this while looking back at this issue. The instance param 'dtemp' will help to simulate a circuit with devices at different temperatures. I know Mentor Eldo supports this feature. Didn't check with other tools.
Ram
Reply #2 - Nov 2nd, 2009, 5:51am
HSpice also uses 'dtemp' like Eldo; Spectre calls it 'trise'
