Jul 16th, 2024, 5:24pm
stability simulation of bandgap (Read 2011 times)
bottom_up
Oct 19th, 2009, 8:23am
Dear all
I want to design a bandgap reference circuit. Now, I have determined which structure I would choose .But I have the problem with which parameters I should simulate and how to simulate them by hsipce.
For example, how to simulate the stability of the circuit . In details, what stimulus I should add to the circuit ,and how to analyze the results.
Thanks a lot.
Bottom
Riad KACED
Swindon, UK
Re: stability simulation of bandgap
Reply #1 - Oct 19th, 2009, 12:48pm
There are many ways to simulate the stability.
The most common one for your BG is to run an AC analysis and look at the open loop gain and phase along with the gain and phase margins. All what you need is a testbench where you put your design and a stimulus with 1V AC DC source (1V to directly read the gain without any divisions). In the old days, we used to open the AC loop and leave the DC loop closed in order to keep all the devices at the right operating point around which you exercise the small signal anaylsis. Nowadays (with Spectre at least), you don't really need to
My advice for you is:
1. Look at your Analog Design book to learn things about feedback analysis, gain, phase ... etc
2. Look at the Hspice doc for more details about the AC analysis. I'm a Spectre user as far as I'm concerned.
If you are really in a hurry, then run a quick transient and if it the output oscillates then it is instable  :-[
Cheers,
Riad.
Riad KACED
PDK, EDA Support Engineer.
raja.cedt
Reply #2 - Oct 19th, 2009, 9:58pm
hi,
   one point i would like to add is break the loop where both +ve and -ve feedback are intersecting.
Rajasekhar.
glacieryy
Reply #3 - Oct 22nd, 2009, 7:04am
Hi,all
I have met a similar  problem is ,the amplifier used in my bandgap is self_biased. In detail ,the output of the amplifier is the input(gate voltage) of the bias mosfet. In this case ,I am puzzled  with how to break the loop.
glacier
yvkrishna
Reply #4 - Oct 23rd, 2009, 4:51am
hi glacier,
Breaking at the output of the amplifier is the only way to break all the loops in this case.
thanks,
vamshi
raja.cedt
Reply #5 - Oct 23rd, 2009, 8:24am
hi glacier,
                i guess self bias means all bias voltages will be generated by internally, so whats the problem while breaking? because while analyzing stability through breaking we should not disturb bias voltage.
rajasekhar.
Riad KACED
Swindon, UK
Reply #6 - Oct 25th, 2009, 4:27am
Hi Glacier,
I have commented a similar topic in the following link.
http://groups.google.com/group/comp.cad.cadence/browse_thread/thread/d3646e55f0c...
The Paper from Ken talks about the closed loop stability analysis.
This is likely to help you with a better understanding of this issue.
Cheers,
Riad.
Riad KACED
glacieryy
Reply #7 - Oct 27th, 2009, 4:23am
Hi,rajasekhar
  The self bias means the Gate Voltage of the Pmos used as the current bias for the amplifier is generated by the amplifier itself ,in details ,the voltage is the output of the amplifier.
  In this case,can I break at the output of the amplifier ?
Glacier
glacieryy
Reply #8 - Oct 27th, 2009, 4:25am
Hi,Riad
Thanks for your links.
Glacier
raja.cedt
Reply #9 - Oct 28th, 2009, 10:36pm
hi Glacier ,
                 yes, you can break because breaking the loop means you are not breaking for dc only for ac signal you are breaking.are you using any start up?  Hope you understand.
thanks,
rajasekhar.
aaron_do
Reply #10 - Oct 29th, 2009, 7:05am
Hi Rajasekhar,
can you elaborate on this point?
what do you mean by this?
thanks,
Aaron
raja.cedt
Reply #11 - Oct 29th, 2009, 10:10pm
hi Aaron,
              what i want to convey is when you are ding stability analysis for ckts have both +ve and -ve feedback break the loop at the common point of both loop so that at a time we can break both loops.
thanks,
rajasekhar.
