Jul 16th, 2024, 10:25pm
Lambert-W function in verilog-A (Read 740 times)
337see733
Singapore
Sep 21st, 2007, 1:22am
Dear all,
Has anyone implemented Lambert-W function in verilog-a and willing to share ?
Thanks.
View Profile gilbertsee   IP Logged
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: Lambert-W function in verilog-A
Reply #1 - Sep 26th, 2007, 1:39am
There is a description including Python code for a solution based on a recurrence relation or a solution based on an approximation at Wikipedia. That is if you're using real valued arguments.
http://en.wikipedia.org/wiki/Lambert's_W_function
It is quite trivial to convert this code to Verilog-A: here is the recurrence relation code:
function real lambertw;
input x, prec, iters, error;
real x, prec;
integer iters, error;
real w, we, w1e;
integer i;
begin
  w = 0;
  for (i = 0; i < iters; i = i + 1) begin
    we = w * exp(w);
    w1e = (w + 1) * exp(w);
    if (prec > abs((x - we) / w1e))
	break;
    w = w - (we - x) / (w1e - (w+2) * (we-x) / (2*w+2));
  error = (i < iters) ? 0 : 1;
  lambertw = w;
endfunction // lambertw
I've not actually run this code, but I think you get the idea.
337see733
Singapore
Reply #2 - Sep 26th, 2007, 6:07pm
Hi Marq,
Will try and see. Thanks.
