Aug 17th, 2024, 9:18pm
Sample and hold models with external clocks (Read 1109 times)
sck236
Sep 26th, 2007, 4:12am
In the paper, "Device noise simulation of Delta Sigma Modulators",
It says that an ideal S/H is used to close the loop for noise simulation.
I tried to use the model in "Simulating switched-capacitor filters with SpectreRF ".
The model, however, is a self-clocked model.
Thus, I couldn't use it for closing the loop which requires an externally clocked S/H.
Does anyone know where I can get an appropriate S/H  model for closing the differential loop?
Thank you in advance.
