Sep 17th, 2024, 8:55pm
diode in CMOS (Read 5089 times)
aaron_do
diode in CMOS
Sep 27th, 2007, 7:05am
If i want to make a diode, i can use a MOS transistor and connect the gate to the drain. However, the diode turn on voltage will equal Vth. Is there a way to have a diode with a turn on voltage closer to zero in CMOS? thanks,
Aaron
Stefan
Re: diode in CMOS
Reply #1 - Sep 27th, 2007, 7:10am
In some CMOS processes there are special low_Vth Transistors (and therefore also diodes) available.
As far as I remember they maybe go down to 0.18 V in CMOS processes.
How low do you need to go ?
View Profile 16731287   IP Logged
ACWWong
Oxford, UK
Re: diode in CMOS
Reply #2 - Sep 27th, 2007, 8:15am
yes using a low vt device if available...... and if your process has a Schottky Diode option thats even more cool....  (both though at the cost of the additional masks)
and of course you can size/bias a normal vth device to tweak its vth within reason (like utilsing short-channel effects or forward body biasing etc).
aaron_do
Re: diode in CMOS
Reply #3 - Sep 27th, 2007, 9:29am
thanks,
how about VPNP? I need it as close to zero as possible really. I'm trying to rectify an RF signal, but the amplitude is only around 500 mV. I'm not trying to detect the power so loss isn't the most important issue...
Aaron
nxing
God help the person
who help themselves
China
Re: diode in CMOS
Reply #4 - Sep 27th, 2007, 9:53am
In some process, for example, TSMC. they provide native device which has the 0v Vth with no additional cost.
However, when you use MOS's diode connection, the I-V relationship is not as same as the real diode. for example, for a long-channel device, I=a*V^2 while in diode, I=e^(-v)....
Re: diode in CMOS
Reply #5 - Sep 27th, 2007, 12:45pm
think outside the box ---
Use a comparator and a switch.
I have made those work up to 200-300 MHz
also, a lot of the diode models on foundry are not accurate at high frequencies.
Jerry
aaron_do
Re: diode in CMOS
Reply #6 - Sep 27th, 2007, 8:48pm
Thanks for the advice.
Actually it would need to work up to 3 GHz...also, the comparator would need a lot of power. My idea was meant to save power Cheesy
Anyway after thinking about it i realized the idea probably wouldn't work even if i had the diode so nvm
thanks,
Aaron
