Sid
If you do not mind a ~40% efficiency, a linear regulator will work! But, I am assuming you want more efficiency. The main problem is I think getting an on-chip inductor with low enough losses. However, even making large enough capacitors on-chip will be a challenge. May be you could consider using an off-chip inductor for your Buck converter. Just a few thoughts ...
-Sid
