Aug 17th, 2024, 7:20am
Pstb Analysis for SC CMFB (Read 4210 times)
analog2000
Oct 04th, 2007, 2:31pm
Could anyone help me with pstb analysis of sc cmfb for a diff amp. I have been trying to run pstb but pss fails for a differntial sc gain. The gain stage uses a diff amp with sc cmfb ?
thanks a lot
Best Regards
analog2000
HdrChopper
Re: Pstb Analysis for SC CMFB
Reply #1 - Oct 6th, 2007, 9:48am
When you say tje pss fails for a differential sc gain, what do you exactly mean: it does not converge or it is giving you unexpected results?
tosei
Keep it simple
analog2000
Reply #2 - Oct 6th, 2007, 2:37pm
HI there,
It fails to finish the pstb analysis. The pss analysis is finished, however, there were convergence warnings. ?
I tried relaxing the accuracy requirements, changed the pss algorithm from balanced to shooting, but of no avail. I also tried changing the clock frequency and the input frequency for my sc gain stage. No luck yet
thanks
analog2000
HdrChopper
Reply #3 - Oct 8th, 2007, 7:37pm
I assume you are using the cmdmprobe from the analoglib. If this is the case, make sure the probe is properly connected according to the type of analysis you are trying to run (-1 for diff mode, 1 for cm mode). I saw convergence problems due to this in the past.
tosei
Keep it simple
analog2000
Reply #4 - Oct 10th, 2007, 3:34pm
I am not using cmdmprobe
analog2000
