Jul 17th, 2024, 10:34am
Viewing subcircuit internal nodes in AMS Designer (Read 2888 times)
IVerify
Oct 05th, 2007, 12:11pm
I am unable to view the internal nodes of a Spectre subcircuit in an AMS Designer simulation.  I can only see the nodes that are in Verilog-AMS.  Here's what I have.
top.vams
`include "constants.vams"
`include "disciplines.vams"
module top ( );
  electrical vdd;
  electrical vss; ground vss;
  sub sub1 (.vdd (vdd), .vss (vss));
  analog V(vdd) <+ 2.5;
subcircuit.scs
simulator lang=spectre
subckt sub (vdd vss)
r1 (vdd out) resistor r=1k
r2 (out vss) resistor r=1k
ends sub
top.scs
tran tran stop=100u save=all
saveNodes options save=all
run.tcl
database -open output -into out -default
probe -create top -depth all -database output -waveform
probe -create -emptyok -database output -flow -ports -depth all
run 1us
exit
Makefile
all:
	  rm -rf INCA_libs out
	  ncvlog -ams top.vams
	  ncelab top -modelpath subcircuit.scs -messages -access +rwc
	  ncsim -ams top -analogcontrol top.scs -messages -input run.tcl
When I type:
make
simvision &
I only see top.vdd, top.vss (and the currents).
I want to be able to see sub1.out
Any suggsetions?
ACWWong
Oxford, UK
Re: Viewing subcircuit internal nodes in AMS Desig
Reply #1 - Oct 6th, 2007, 5:42am
If you want to see the node sub1.out (in this case 1.25 volts) then you can do the following:
insert the subckts info control statement into top.scs as follows:
subckts info what=subckts where=rawfile
now after running your simulation, you'll get a top.raw results directory.
using wavescan you open the top.raw directory and read the tran.tran results file which will have the sub1.out terminal available for plotting. Unfortunately i don;t think simvision understands the .tran files.... perhaps someone else knows a more elegant method other than making out an explicit terminal ??
cheers
aw
« Last Edit: Oct 6th, 2007, 11:34am by ACWWong »
