Jul 16th, 2024, 10:31am
Veriloga model of a current limted voltage source (Read 1770 times)
mattpace
Oct 10th, 2007, 6:53am
I'm trying to model a current limited voltage source using veriloga.
I thought it would be trivial, but it has turned out not to be.
Has anyone done this please?
Jess Chen
California Bay Area
Re: Veriloga model of a current limted voltage sou
Reply #1 - Oct 10th, 2007, 8:20am
I have done this before with a resistance that draws current away from the output when the voltage exceeds a threshold. However, if I were to do it today, I would employ a trick that has served me well for the dual problem (a voltage limited current source). I placed a current feedback loop around a controlled voltage source and clamped the input to the controlled source. Within the limits of the input-referred clamp, the feedback loop forces the current to track the input. Once the input tries to exceed the clamp, the controlled voltage source limits and the output clamps at the desired voltage.
I am fairly sure you could do the same for a current limited voltage source. Place a voltage feedback loop around a controlled current source and limit the input to the controlled current source.
Reply #2 - Oct 10th, 2007, 10:09am
You can also modify the ideal diode model given on the Verilog-AMS page to mimic a voltage source with current limiting. If you don't understand the ideal diode model, it is described in chapter 3, section 6.3 of The Designer's Guide to Verilog-AMS (http://www.designers-guide.org/Books/dg-vams/index.html).
mattpace
Reply #3 - Oct 11th, 2007, 6:11am
Thank you for your interest and responses.
Below is what I've come up with so far, it kinda works,
but it oscillates (using Sprectre).
I would have thought someone would have needed to
create a model of this, but I cannot find one.
Any feedback will be greatly appreciated !!!
`include "constants.vams"
`include "disciplines.vams"
module vdc_i_limited(vp, vn);
electrical vp, vn;
  parameter real imax = 0.003; // current limit
  parameter real vdc  = 5.000; // V set
  parameter real rsource = 1000;
  real idc;
  real vout;
  real rload;
  analog begin
    @ (initial_step) begin
      vout = vdc;
      idc = I(vn,vp);
    idc = I(vn, vp);
    if (idc > 0.0) begin
      rload = V(vp,vn)/I(vn,vp);
    if ( idc < imax ) begin
      vout = vdc;
    else begin
      //$strobe("idc = ", idc);
      vout = rload*imax;
      if (vout > 5.0) begin
        vout = 5.0;
    V(vp,vn) <+ slew(vout, 5e6);
Reply #4 - Oct 11th, 2007, 12:44pm
You should start with the ideal diode model, it deals with the oscillation problem. Just change the zeros to the values you want and change the condition to switch at the right point.
Peruzzi
Reply #5 - Apr 16th, 2008, 4:37pm
This topic is a few months old, but I just saw it today when I needed to model a current-limited voltage source.  My solution isn't original to me, I extracted it from http://www.beigebag.com/case_logical_9.htm "Logical Expressions - NO Smooth Switches and a Current Limited Voltage source".
But it's a nice solution, so here it is in easy to use form:
// Current limited voltage source
//                   imax
//         vint ---| --> |------> vp
//             |            / Rnil
//             |_____|/ |___|
//             |     |\ |    va
//              ----------------> vn
 electrical vp, vn;
 electrical vint, va;
  parameter real imax = 0.017; // current limit
  parameter real vdd  = 3.4;   // V set
  parameter real Rnil = 1e-9;
  analog begin
    V(vint,vn) <+ vdd;
    I(vint,vp) <+ imax;
    I(vp,va) <+ V(vp,va) / Rnil;
    @(cross((V(va,vint) + I(va,vint)),0))
    if((V(va,vint) + I(va,vint)) > 0)
       V(va,vint) <+ 0;
    else
       I(va,vint) <+ 0;
And a test circuit that sweeps a resistive load:
// Test vdc_i_limited model
//                (n) ----------
// vdc_i_limited  |     |       \  Rsweep
//                (0) ----------
simulator lang=spectre
ahdl_include "vdc_i_limited.vams"
V1  (n 0) vdc_i_limited
Rsweep  (n 0) resistor R = 400
doDCop dc print=yes
doDCswp dc start=400 stop=100 step=1 dev=Rsweep
The drawings got messed up, but you get the idea... Maybe attaching an ascii file...
Peruzzi
Reply #6 - Apr 16th, 2008, 4:46pm
I should also mention the ideal-diode code (comments added below) comes directly from Ken's Chapter 3, section 6.3.
//                   imax
//             |            / Rnil
//             |_____|/ |___|
//             |     |\ |    va
 electrical vp, vn;
  analog begin
    V(vint,vn) <+ vdd;
    I(vint,vp) <+ imax;
// Ideal Diode
       V(va,vint) <+ 0;
    else
       I(va,vint) <+ 0;
// End of ideal diode
//                (n) ----------
//                (0) ----------
doDCop dc print=yes
