Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 15
th
, 2024, 4:25am
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› Ku-Band Power Detection
Previous topic
Next topic
Ku-Band Power Detection (Read 2341 times)
JDinSLC
Oct 11
th
, 2007, 1:08pm
I need to design a diode detector that works at 14 to 15 GHz over an 80 dB dynamic range. Has anyone done this before? What's a good device to use?
Thanks for any help,
JD
IP Logged
Re: Ku-Band Power Detection
Reply #1 -
Oct 11
th
, 2007, 2:16pm
RSSI (Received Signal Strength Indicator) Poke around in the IEEE JSSC and MTT for papers. Look for RSSI and log amps.
A simple diode wont have the dynamic range you need. Consider a log amplifier which is followed by the AC to DC conversion system. Current hungry device because it needs to run at frequency.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
