Aug 15th, 2024, 9:47pm
Rapid IP3 simulation (Read 2296 times)
hamed
Athens, Greece
Oct 12th, 2007, 2:34am
Hi
I have two similar LNA (in terms of architecture), one working in VHF and the other in UHF band.
Applying the Rapid IP3 Simulation with PAC and PSS Analyses (as mentioned in a paper from Ken Kundert), I have correct and reasonable results for the UHF LNA tuned in its typical channel. Doing the same for VHF LNA I see something strange; the IP3 is lower than CP!! by around 11dBm. Could somebody please help me on this?
Hamed
Re: Rapid IP3 simulation
Reply #1 - Oct 12th, 2007, 2:57am
Hi.
If nonlinearity is dominated by input characteristics, IIP3 will be larger than P1dBin by about 10dB.
But if nonlinearity is dominated by output, for example, output is saturated by low power supply voltage,
IIP3 could be lesser than P1dBin.
Check whether output node is at near saturated operation point.
« Last Edit: Oct 12th, 2007, 8:37am by pancho_hideboo »
