vivkr
HI James,
What exactly are you trying to do with your opamp? Also, when you say 1Vpp, does it mean that (Vip-Vim) varies from -0.5V to +0.5V, or do you mean that it varies from -1.0V to +1.0V? As per your statement, I would imagine it to be the former, in which case each signal swings about +/- 0.25 V around a fixed input common-mode. This can be managed without complementary structures and it is probably unwise to use complementary structures unless there is no way out.
Secondly, is this signal swing only at the input of the overall feedback amplifier or really at the inputs of the opamp? If the former, then you have some sort of resistive or other element interposing between the inputs of the overall amp, and the inputs of the opamp.
Regards Vivek
