Aug 15th, 2024, 3:29pm
sweep LO (Read 2153 times)
aaron_do
sweep LO
Oct 16th, 2007, 8:35pm
i need to simulate a UWB mixer. The IF is assumed constant, and the LO needs to be swept from 3-10 GHz. How would i simulate this using spectreRF? Normally using PSS and PXF you can easily sweep the RF signal but not the LO.
thanks,
Aaron
Re: sweep LO
Reply #1 - Oct 17th, 2007, 1:02am
Hi.
Use "Tools/Parametric_Analysis" in ADE.
Or use OCEAN script.
