Aug 16th, 2024, 7:12pm
Cascaded or Single_Loop DSM ADC (Read 10477 times)
Oct 17th, 2007, 12:41am
Hi.
When we consider architectures of DSM(Delta Sigma Modulator) ADC,
there are three typical architectures like following.
(1) High Order Single Loop
(2) Cascaded (MASH)
(3) Hybrid of (1) and (2)
If we consider power consumption, occupied area, device mismatch,
DT(Discrete Time such as SCF), CT(Continuous Time), stability and SNQR issues,
above three architecture candidates have merits and demerits each other.
It seems that cascaded type DSM ADC is not so popular in actual product.
I know that device mismatch effect is severe in (2).
But about stability, (2) is superior than (1).
Why is not Cascaded DSM ADC popular ?
« Last Edit: Oct 17th, 2007, 10:06am by pancho_hideboo »
Berti
Re: Cascaded or Single_Loop DSM ADC
Reply #1 - Oct 17th, 2007, 3:43am
Hey,
(2) Cascaded (MASH)
what do you mean with hybrid converter?
Because a cascaded modulator with high order first stage doesn't make sense.
I think the reasons that there are not so many cascaded modulators are:
  • Many modulator are CT; and a cascaded CT modulator is difficult to design
  • Single-loop (multi-bit) are much more tolerant to non-idealities (e.g. cap mismatch,
    OTA gain etc.) and are therefore preferred. Furthermore, deep-submicron technologies
    favour the design of comparators and DEM (used for multi-bit quantizers) rather than
    OTAs with high gain.
Reply #2 - Oct 17th, 2007, 4:01am
Thanks for response.
Hybrid I'm meaning is for example, three cascaded stages like following.
   1st-order + 1st-order + 2nd-order(single-loop)
It seems multibit with DEM is most high performance and main stream of DSM ADC.
Berti
Reply #3 - Oct 17th, 2007, 7:29am
I think so....
...but on the other hand I also think that people often do such decisions according to "unscientific"
statements like "cascaded modulators suffer from noise-leakage" or "CT modulator consume less
power than DT". Maybe that's why CT single-loop is so popular..?..
In theory this might be true. But many CT modulators consume more power than DT modulators because
of wrong design decisions. Therefore depending on the specifications, a cascaded modulator might also
be good choice (and a good design won't suffer from noise leakage).
As you correctly wrote:
Quote:
...architecture candidates have merits and demerits each other.
Reply #4 - Oct 17th, 2007, 8:45am
Hi.
I think CT cascaded DSM is very difficult to design.
So cascaded architecture almost require implementation as DT(SCF).
I still want to pursue any possibility of 1bit quantizer.  :P
Berti
Reply #5 - Oct 17th, 2007, 10:18pm
Hey,
consider the design of a tri-level quantizer instead of a 1bit quantizer. As long you make sure that the offset of the amplifier is always transfered,
a tri-level quantizer is inherently linear but drastically reduces quantization noise compared to 1 bit.
vivkr
Reply #6 - Oct 18th, 2007, 2:45am
Berti wrote on Oct 17th, 2007, 10:18pm:
Hey,
Hi Berti,
Could you please elaborate on this point? Why would a tri-level quantizer drastically improve quantization noise? If one purely considers
the number of quantization levels, not much has changed. Are you implying that the linearization of the quantizer characteristic allows larger
input signal without impairing stability, or is there some other reason? One reason I can see is that the presence of 3 levels would mean that the
quantizer output idles around the mid-level most of the time when the input signal is very small, thereby reducing the amount of out-ofband noise
that needs filtering, but this would not hold for larger signals.
Hi Pancho,
Also consider multibit quantizers and single-loop DSM. With mismatch shaping and dithering, you can get excellent performance and the design
is considerably simplified.
Vivek
Reply #7 - Oct 18th, 2007, 3:24am
Hi, vivkr.
I think multibit with DEM must be most high performance and main stream of DSM ADC.
But I'm considering adopting DSM to RF signal. So low resolution quantizer(feedback DAC)
is preferable.
Berti
Reply #8 - Oct 18th, 2007, 5:25am
Hi Vivek,
As you wrote:
a) A tri-level quantizers increases the max.input signal
b) The mid-level reduces the output power of the quantizer. See the paper:
J.J.Paulos et.al., "Improved Signal-to-Noise Ratio Using Tri-Level Delta-Sigma Modulation",
IEEE Proceedings of the Int. Symp. on Circ. and Systems, May 1987.
Pancho,
what sampling-rate do you plan for modulator?
Reply #9 - Oct 18th, 2007, 9:17pm
Hi, Berti.
I plan to sample at about 1GHz.
So I think DT(SCF) modulator result in large power consumption.
I read old paper you teach about Tri-Level Delta-Sigma Modulation if I can get it.
vivkr
Reply #10 - Oct 18th, 2007, 11:07pm
Hi Pancho,
I doubt if sampling a DT SCF based modulator at 1 GHz will lead to a very efficient design.
Maybe it really is worthwhile considering the use of a CT modulator, especially if you are
only interested in a narrowband of signals around RF. You could use a bandpass modulator.
It will probably be much more power-efficient and effective even with additional circuits
for removing process variations of the coefficients and for generating an on-chip frequency.
A very good paper on a similar topic is to be found in JSSC, Dec. '06 by Mitteregger et al.
A 20-mW 640-MHz CMOS Continuous-Time SigmaDelta ADC With 20-MHz Signal Bandwidth; 80-dB Dynamic Range and 12-bit ENOB
The authors there use a CT DSM but decimate down the output on-chip to get an effective Nyquist bandwidth of about 20 MHz at baseband. From a system
and circuit design point of view, this is an excellent ADC scheme. You could make good use of the applied principles here.
Vivek
Reply #11 - Oct 22nd, 2007, 12:29am
Hi, Vivek.
Of course, I know CT-DSM you refer. This DSM is published at ISSCC 2006.
Features of this ADC are 4bit-3rd-Order-CT-DSM using NRZ-DAC with combination of Feedback and Feedforward.
I know 4bit quantizer is main stream in current DSM ADC.
The following paper's DSM ADC is also 4bit.
Richard Screier, et al.,"A 375mW Quadrature Bandpass DSM ADC with 90dB DR 8.5MHz BW at 44MHz", ISSCC 2006.
As I said in previous post, I still want to pursue any possibility of 1bit or less resolution quantizer.
I have interests in the approaches of following papers.
B.Putter, "A 5th-order CT/DT Multi-Mode DSM Modulator", ISSCC 2007.
Lucien J.Breems, et al., "A 56mW CT Quadrature Cascaded SDM Modulator with 77dB DR in a Near Zero-IF 20MHz Band", ISSCC 2007.
« Last Edit: Oct 22nd, 2007, 7:20am by pancho_hideboo »
Berti
Reply #12 - Oct 22nd, 2007, 1:58am
Hi Pancho,
I guess that your amplifier will require a very high bandwidth to avoid phase shift (-> excess loop delay).
The nested-miller amplifier used by Mitteregger can provide very high bandwidth at reasonable current.
The other papers your mention (Putter and Breems) use a SC DAC. I think that solution will consume
more power (higher bandwidth for settling required) and probably prohibits the use of a nested-miller
amplifiers (pole-zero doublet deterioate settling).
On the other hand using a 1bit quantizer might result in very tough jitter requirements. A multi-bit quantizer
could relax that....
vivkr
Reply #13 - Oct 23rd, 2007, 12:01am
Hi Pancho,
Berti makes some important points. An SC-DSM would be a very hard undertaking from every front, and a
1-bit quantizer also would make life much harder.
Please note the various things that Mitteregger et al. have done. I will point out the key points I saw inthat
paper:
1. Use of CT DSM + mild input antialias filtering (not mentioned but there must be atleast some) implies
that system works in CT mode, that is no steps or any sharp transients on the input.
2. Since system is CT with no transients, it is possible to use pole-zero compensation in the opamp to
achieve wide bandwidth. No transients => step response not important, only steady-state response => bandwidth
only needs to be much much lower => lower noise, lower power.
3. Use of a latch in the DAC feedback path => comparator metastability not important. This in reality is a much
larger contributor to DAC jitter than just the clock jitter (see papers by Cherry & Snelgrove on this topic). The half-cycle
delay is compensated in the loop filter itself, and should partially reduce sensitivity to phase delay in the opamps (atleast
to my understanding but I may be wrong on this point).
You can use methods to shape mismatch in a multibit DAC. Of course, if you are constrained to use a 1-bit quantizer
due to system restrictions, then it is another story.
Maybe some SDM experts can add their comments here.
Vivek
