shaikh_sarfraz
Hi, I have to model a sensor block in Verilog-AMS. The problem is some thing like this:
I have 32 arrays of real values. Each array holds 40 real values.
A0[39:0]= 3 a 4 5 2...............e 1 A1[39:0]=............................... .............................................. .............................................. A31[39:0]=..........................d 6
Now I have to select each array and take each real value in that array at a time and after some processing assign it into output analog port.
The statements will look like this
electrical [39:0] OUT genvar i,j; real dp,pd;
/*There will be 32 real arrays declared*/ real [39:0] A1; real [39:0] A2; ....... ....... real [39:0] A32;
analog@(initial_step) begin
for (i=0;i<32;i = i+1)
begin if (i == 0) begin for (j=0;j<40;j = j+1) begin dp = A0[j] ; pd = 1.5 - 1.05 - dp/55; V(OUT[j]) <+ pd; end end
if (i == 1) begin for (j=0;j<40;j = j+1) begin dp = A1[j] ; pd = 1.5 - 1.05 - dp/55; V(OUT[j]) <+ pd; end end ........ ......... ....../*Here we will assign each real array(A0[39:0], A1[39:0]......A31[39:0]) to the output port (OUT[39:0]) one at a time, so there will be 32 if statements for passing 32 real arrays*/
if (i == 31) begin for (j=0;j<40;j = j+1) begin dp = A31[j] ; pd = 1.5 - 1.05 - dp/55; V(OUT[j]) <+ pd; end end end end
Here is the list of problems which we are facing: 1). We cannot assign electrical (analog) ports (OUT[39:0]) inside for loop. 2). To solve this problem we used generate statement. But we cannot use nested generate loop.
In short our problem is that we have 32 arrays with each array holding 40 real values. Now we have to pass each of these 40 real values to the 40 bit analog output. And in between we have to process (manipulations) each of these 40 real values , so it requires nested loops.
It seems like the Verilog-AMS language (and AMS simulators) has few limitations due to which this problem is not getting solved. I will appreciate any help for any body for providing any work around for this problem.
Regards Sarfraz
