Sep 16th, 2026, 10:20pm
Running the AMS simulator with an OCEAN Script (Read 3499 times)
Rob
Oct 31st, 2007, 12:24am
I am trying to run the AMS simulator with an OCEAN Script.  My simulation is quite large, so I only want to save the voltages of the analog nets that I am interested in.  When I save the desired voltages with the command,
>save( 'v "/net1" "/net2" ),
all other analog voltage nets in the simulation are saved as well.  I tried explicitly setting the save mode to selected with the command,
>saveOption( 'save "selected"),
with no change in results.  I also tried changing the save mode by including a simulation file that includes the command,
>Name options save=selected,
which also yielded no change in the result.  Although, when I set this last option to save=none, I get no saved data, as expected.  So it seems I can save all or none of my analog nets.  Does anyone have any suggestions how I can save only the nets I want.
Rob
jbdavid
Re: Running the AMS simulator with an OCEAN Script
Reply #1 - May 2nd, 2008, 12:39am
using ocean to probe the signals, leaves an extra layer between the simulator and the commands..
I finally started writing tcl scripts to setup the signals to save and plot..
and discovered that its also allows me to control/modify the simulation itself, change values, run tasks etc..
now this only works for AMS, but it works quite well and gives you access to all simulation signals & variables not just schematic nets.
jbdavid
