Rob
I am trying to run the AMS simulator with an OCEAN Script. My simulation is quite large, so I only want to save the voltages of the analog nets that I am interested in. When I save the desired voltages with the command, >save( 'v "/net1" "/net2" ), all other analog voltage nets in the simulation are saved as well. I tried explicitly setting the save mode to selected with the command, >saveOption( 'save "selected"), with no change in results. I also tried changing the save mode by including a simulation file that includes the command, >Name options save=selected, which also yielded no change in the result. Although, when I set this last option to save=none, I get no saved data, as expected. So it seems I can save all or none of my analog nets. Does anyone have any suggestions how I can save only the nets I want.
Rob
