Aug 15th, 2024, 6:34pm
counter (Read 2981 times)
kamath
counter
Oct 31st, 2007, 4:54am
hai,
i have coded a counter block ,could some one help me as i am not getting the required waveform at output:
// VerilogA for project, counter, veriloga
`include "constants.vams"
`include "disciplines.vams"
module counter(incnt,cntclk,cntout,rst);
input  incnt,cntclk,rst;
output cntout;
electrical incnt,cntclk,rst,cntout;
real step;
parameter real vtrans=0.3;
parameter real maxstep=15;
parameter real minstep=0;
analog begin
@(cross(V(cntclk)-vtrans,1))
       begin
               if((V(incnt)-vtrans)>0)
                       step=step+1;
               else
              step=step-1;
if(step>maxstep)
step=maxstep;
if(step<minstep)
step=minstep;
if(V(rst)>0)
step=0;
V(cntout)<+step;
please help me as i am new to verilog-ams.
thank you
Re: counter
Reply #1 - Oct 31st, 2007, 6:53am
Fix your begin/end blocks as indicated below.
kamath wrote on Oct 31st, 2007, 4:54am:
hai,
output cntout;
real step;
analog begin
       begin
                       step=step+1;
               else
              step=step-1;
               if(step>maxstep)
                 step=maxstep;
               if(step<minstep)
                 step=minstep;
       end // add this one
if(V(rst)>0)
step=0;
V(cntout)<+step;
//end -- remove this one
thank you
Re: counter
Reply #2 - Oct 31st, 2007, 6:58am
Actually, you may need the "end" to be added right before
V(cntout)<+step;
if you want the reset to only happen on clock edges.
