Hello, I am trying to instantiate a Spectre voltage pulse source in my Verilog-A code like so:
vsource #( .type("pulse"), .val0( vss ), .val1( vdd ), .delay( tdel ), .rise( trise ), .fall( tfall ), .width( twidth ), .period( tperiod ) ) v1( a, b );
I get the error that "delay" is a reserved name of a simulator library function.
How can I instantiate this module without running into this delay error? It seems I must pass the parameters this way, as just passing the values in order doesn't work.
Help!
