Aug 16th, 2024, 7:19pm
Step size of charge pump output!! Help (Read 3035 times)
kim57
Oct 31st, 2007, 7:42am
I would like to ask anyone have the equation or know how to derive the equation for the step size of the charge pump output voltage??
Since the step of the output getting smaller when it reach the maximum value, so anyone know how to derive that?
Thank you
Stefan
Re: Step size of charge pump output!! Help
Reply #1 - Oct 31st, 2007, 9:46am
What about Ohm's law ? Smiley
A charge pump (see the name?) should deliver a specified current, not a voltage.
View Profile 16731287   IP Logged
Berti
Reply #2 - Nov 1st, 2007, 8:17am
Hi Kim,
many kind of circuits are entitled as "charge pumps". You should therefore be more precise.
But I think you talk about a "voltage-boost" circuit. When you write down the equation for charge conservation
for the different phases (like in a SC-circuits), you should get the answer you are looking for...
kim57
Reply #3 - Nov 1st, 2007, 9:04am
The charge pump that i refer to is same as the one i attached.
