Jul 2nd, 2025, 6:20am
Instantiating a Spectre source in Verilog-A (Read 3125 times)
Croaker
Nov 05th, 2007, 1:24pm
Hello,  I am trying to instantiate a Spectre voltage pulse source in my Verilog-A code like so:
vsource #( .type("pulse"), .val0( vss ), .val1( vdd ), .delay( tdel ), .rise( trise ), .fall( tfall ), .width( twidth ), .period( tperiod ) ) v1( a, b );
I get the error that "delay" is a reserved name of a simulator library function.
How can I instantiate this module without running into this delay error?  It seems I must pass the parameters this way, as just passing the values in order doesn't work.
Help!
Cry
Re: Instantiating a Spectre source in Verilog-A
Reply #1 - Nov 6th, 2007, 6:06am
Annex E of the Verilog-A LRM says you should do:
vpulse #(.val0( vss ), .val1( vdd ), .td( tdel ), .rise( trise ), .fall( tfall ), .width( twidth ), .period( tperiod ) ) v1( a, b );
Croaker
Reply #2 - Nov 7th, 2007, 11:27am
Thank you!  I did some digging and found another workaround.  The reserved function 'delay' must be escaped, like so:
.\delay ( tdel )
Put a '\' before the word and a ' ' (space) after it.
Cheers!   Smiley
