Berti
Usually you design-kits contains models for different process corners. However, for very advanced technologies, the traditional corner model (fast, slow, typ) is obsolete and you better use statistical (monte carlo) simulation (you models should containt statistical data).
So, just run the simulations again with different corners models or use monte-carlo simulations.
