Aug 15th, 2024, 8:13am
Are these enough for mixer simulation before fab? (Read 3314 times)
aboco
Nov 16th, 2007, 6:36pm
I am designing a passive mixer with integrated LO buffer using ADS tool, pHEMT process.
Target mixer should have high IIP3, P1dB given a reasonable low LO drive over an RF bandwidth.
I don't have any experience on this.
Simulations I have carried out include:
1. Conversion Gain and Noise Figure: over the RF bandwidth and LO power sweep
2. RF-IF compression (P1dB): over the RF bandwidth and LO power sweep
3. IIP3, isolations: over the RF bandwidth and LO power sweep
4. Ports' return loss
5. SFDR
6. Temperature dependence for all parameters: over a required range of working temperature
(All these include layout affect)
Are these enough for mixer design or is there anyone simulation else should I conduct before having it fabricated?
Any experienced one could give me advice on this design procedure. I would really appreciate your help.
aboco
Berti
Re: Are these enough for mixer simulation before f
Reply #1 - Nov 18th, 2007, 10:43pm
You should also analyze the effect of process variations...
... but in general I think you simulation is only as good as the model you simulate.
Even when your simulator predicts perfect results, your chip might still not work properly.
Therefore I think that a good understanding of the circuit and its potential problems, the
models you use, and the effects not modelled in the simultation (package?, coupling? etc.) is
similar (or even more) important than just to rely on the simulator.
aboco
Reply #2 - Nov 21st, 2007, 8:53pm
Thank you Berti for advices.
Plz give me example about process variation analyzing.
aboco
Berti
Reply #3 - Nov 22nd, 2007, 7:51am
Usually you design-kits contains models for different process corners. However, for very advanced technologies,
the traditional corner model (fast, slow, typ) is obsolete and you better use statistical (monte carlo) simulation
(you models should containt statistical data).
So, just run the simulations again with different corners models or use monte-carlo simulations.
