Aug 17th, 2024, 3:21am
Sigma-Delta MOD1: Quantizer gain (Read 4796 times)
neoflash
Mixed-Signal
Designer
Nov 17th, 2007, 2:05am
In text books, the MOD1 z-domain model assumed quantizer gain as 1 for analysis.
Is this correct?
What if the gain is different from 1, any analysis done there?
vivkr
Re: Sigma-Delta MOD1: Quantizer gain
Reply #1 - Nov 19th, 2007, 2:32am
Hi neoflash,
The quantizer gain can only be assumed to be 1 for multibit quantizers and for reasonably large signal swing at quantizer inputs.
As far as I know, the quantizer gain needs to be calculated from the signal statistics for a 1-bit quantizer.
And the textbooks also do it this very way. I would recommend that you look at the textbook by Schreier &
Temes or the TCAS paper by Baird & Fiez.
Vivek
neoflash
Mixed-Signal
Designer
Reply #2 - Nov 19th, 2007, 6:09am
thanks for your reply.
Then why in z-model, the gain is assumed to be "1" to get desired NTF and STF?
vivkr
Reply #3 - Nov 21st, 2007, 7:34am
Which z-model do you mean???
If it assumes a gain of 1, then there is the general assumption that the quantizer
is not being overloaded. For a 1-bit quantizer, I would suggest that one still does
not set the gain blindly to 1. However, it is probably used because it is easy to set
it to 1. The references I mentioned cover the topic in greater detail.
Vivek
Berti
Reply #4 - Nov 21st, 2007, 10:27pm
Hi Neonflash,
In the classical model, the quantizer gain has to be 1 when you assume a
unity closed-loop gain for the modulator.
However, Vivek is right. That gain will change depending on the input signal.
Signal-statistics are usually used to calculate the quantizer gain (and to
determine stability).
