Aug 16th, 2024, 7:16pm
BSIM: System of Units (Read 5245 times)
tariavo
Nov 22nd, 2007, 4:12am
Hi!
What system of units is used in BSIM?
It seems to be MKS (or SI) but there is a strange divergence about Epsilon:
from eq1 (pic1) we can get:
[epsilon] = 1
but from eq2 it resuls in:
[epsilon] = coulomb/v/m
What is wrong?
tariavo
Re: BSIM: System of Units
Reply #1 - Nov 22nd, 2007, 4:13am
equation 1 (pic1):
tariavo
Reply #2 - Nov 22nd, 2007, 4:14am
eq2 (pic2):
tariavo
Reply #3 - Nov 22nd, 2007, 4:17am
Oh, in BSIM's manual [EPSROX] = 1, but it should be [EPSROX] = coulomb/v/m and it is necessary to multiply it by 8.85E-12 in all equations.
am i right?
Reply #4 - Nov 26th, 2007, 8:26am
EPSROX is the ratio of the oxide permittivity to that of free space, so it should always appear as EPSROX * Eps0 in equations, eg:
 model->BSIM4coxe = epsrox * EPS0 / toxe;
from the source code (b4temp.c).  Is there a typo in the equation?  Perhaps it used to say EPSOX ( = 3.9 * EPS0 for SiO2) and the equation was changed to EPSROX instead of EPSROX * EPS0 when allowing for other oxides.
tariavo
Reply #5 - Nov 27th, 2007, 6:52am
thanks! and another question arised about the use of BSIM's code:
http://www.designers-guide.org/Forum/YaBB.pl?num=1196175062
