Jul 20th, 2024, 10:11am
subckt (Read 977 times)
orion
subckt
Nov 26th, 2007, 7:22pm
I am trying to run a spectre simulation using a subckt which is defined in a file.
for simplicity, I will define a simple test file:
in a file ckt.scs, the following lines are included which I load into the ADE Setup->Model Library Setup
subckt testcell (1 2 99)
parameters a=5 b=a*6+4
c0 ( 2 99) capacitor c=a
l0 ( 1 2) inductor l=b
ends testcell
the top circuit schematic is simple so the netlist looks like
simulator lang=spectre
global 0
include "/home/user/ckt.scs"
// Cell name: testcell
// View name: schematic
subckt testcell A B SUB
ends testcell
// End of subcircuit definition
// Cell name: ttest
I0 (net1 0 0) testcell
V0 (net1 0) vsource mag=1 type=dc
simulatorOptions options .....
dc0p dc write......
The schematic for testcell just has ports drawn since the circuit  is defined in the subckt file ckt.scs
The error message that I receive in the simulator output when running is
Error found by spectre during circuit read-in.
"input.scs" 14: 'testcell' is being redefined
How can I get this to work if I want to include the subckt definition in the file ckt.scs and without manually changing the input.scs file?
achim.graupner
Re: subckt
Reply #1 - Nov 26th, 2007, 9:52pm
Hi orion,
the problem of you spectre netlist is the re-definition of the subckt testcell. In order to avoid the netlister to netlist the empty schematic you may try just to delete that cellview. Maybe you have to add "symbol" as stopping view in the view switch list.
HTH,
Achim
Achim Graupner
ZMD AG, Dresden, Silicon Saxony, Germany
orion
Re: subckt
Reply #2 - Nov 27th, 2007, 11:30am
Hello Achim,
Just deleting the schematic view didn't work and the stop view list settings in the environment options would effect the
entire top level schematic.  In using this block "testcell", it would be connected with other symbols blocks with schematics in them.
-orion
achim.graupner
Re: subckt
Reply #3 - Nov 28th, 2007, 12:13am
Hello Orion
what about using a VerilogA description instead of a subckt? IN VerilogA you can use structural description as well as parameters,
If you need, I could provide you a code example.
Achim
Achim Graupner
orion
Re: subckt
Reply #4 - Nov 28th, 2007, 11:40am
Achim,
sounds like a solution!
Yes, can u provide me w/an example.
thanks!
-orion
