Aug 15th, 2024, 4:25pm
flicker noise with switched current source (Read 6185 times)
aaron_do
Nov 28th, 2007, 8:02am
there is flicker noise reduction technique which involves using a switched current source. Just wondering, is this taken care of when simulating with spectre and the BSIM3 model?
thanks,
Aaron
ACWWong
Oxford, UK
Re: flicker noise with switched current source
Reply #1 - Nov 28th, 2007, 2:13pm
If the BSIM3 model card is coded with flicker noise, then spectre and spectreRF will calculate it (in noise or pnoise or transient noise).
So the impact of flicker noise reduction techniques should be seen in simulation. Spectre/spectreRF allows you to see how any individual device noise sources like fn contribute to the output noise (i.e. "noise summary").
In pnoise with noise soures set to time domain, you print the noise summary at different time points of the pss (shooting) steady state, to see at what parts of the cycle fn of each device is contributing.
vivkr
Reply #2 - Nov 28th, 2007, 11:05pm
Hi Aaron,
When you say "switched current source", do you mean that the current source is switched ON and OFF or just commutated? The latter would be modelled by spectreRF, but for the former, you would need a change in the model. I don't believe that the former is modelled by any model at present.
I am speaking of the technique presented by Eric Klumpernik et al. where they turned current sources ON and OFF and the reduction in 1/f noise exceeds the reduction you would expect based on just the reduction in the duty cycle of the switch waveform turning the current ON and OFF. I don't remember the paper title, but it was in JSSC a few years ago. You can Google Klumpernik.
Vivek
aaron_do
Reply #3 - Nov 29th, 2007, 3:54am
Hi Vivek,
that's exactly what i'm talking about. The current source is switched on and off. So i guess it is not modeled. BTW what do you mean by "just commutated"?
thanks,
Aaron
Frank Wiedmann
Munich, Germany
Reply #4 - Nov 29th, 2007, 4:22am
The article you probably want to read is http://icd.el.utwente.nl/publications/get_file.php?pub_id=299. Currently, the effect is not included in any models.
aaron_do
Reply #5 - Nov 29th, 2007, 6:58am
thanks for the help. I was able to get the paper from IEEE xplore
Aaron
borisk
Reply #6 - Dec 13th, 2007, 3:37pm
Aaron, if I remeber correctly, the key in that paper was that the source is switched to negative voltages such that the device is taken to accumulation region thereby somehow lowering flicker noise.
If switched on/off (say below/above transistor Vth) then the noise is being averged by the duty cycle of the switching and should be taken into account by Spectre, but going negative wouldn't as it's a physical mechanism that isn't captured by the BSIM3/4.
Cheers,
Boris
