Jul 2nd, 2025, 11:14am
how to measure waveform using ocean (Read 2092 times)
Julian18
Nov 29th, 2007, 3:30am
Hi, there
    suppose I have a waveform (using getData), and want to see the Y value of the waveform giving a X value,how can I do this using ocean statement.(in stead of using graphical means)
Thanks.
wyyll
Re: how to measure waveform using ocean
Reply #1 - Nov 29th, 2007, 11:57am
signal_wfm = getData("/cool_output");
y_value = value( signal_wfm x_value);
should work for a single transient run.  If the runs are contained within a sweep analysis, then that
parameter can also be added.
Will.
