Jul 16th, 2024, 10:54am
differential charge pump in verilog-a (Read 2416 times)
Maher
Dec 06th, 2007, 3:14am
Hi folks,
there's a verilog-a description of a single ended charge pump in the library ahdlLib in cadence.
can you help me to model in verilog-a a differential charge pump connected to a filter and to 2 current source (see circuit below), one between (+phase & -phase), the second one connected between (+frequency & -frequency).
           R                                     C                       R
+phase                 +frequency               -frequency                           -phase
thank you very much
Maher
