haikom
Hi, yes you can edit a schematic or layout using SKILL. E.g. PCELLS are also SKILL based. Please refer to the document "Virtuoso Schematic Editor SKILL Functions Reference". You will find it inside the DFII install hierarchy (../CDSDIR/doc/...) To create a wire you can use the following command: schCreateWire( cv "draw" "full" list(0:0 1:0) 0.0625 0.0625 0.0 ) To create an instance: symbolId = dbOpenCellViewByType( "test" "inv1" "symbol" "" 'r ) instId = schCreateInst( cvId symbolId "I25" 0:0 "R90" )
Regards, haikom
