Sep 27th, 2026, 6:50pm
how to change schematic automatically (Read 5407 times)
Julian18
Dec 09th, 2007, 6:53pm
Hi, there
    I have a heap of pins and wires to be added to my schematics, can I do that automatically using skill code??
thanks.
Re: how to change schematic automatically
Reply #1 - Mar 19th, 2008, 7:17am
I would assume so.  I know we have skill code that automatically adds a bunch of instances.
Pins should be easy; don't know if adding the wires is hard if you have to position them accurately to connect to the pins.  We just name the nets on the terminals  of our instances, so we don't need wires.
haikom
Reply #2 - May 3rd, 2008, 12:44pm
yes you can edit a schematic or layout using SKILL. E.g. PCELLS are also SKILL based. Please refer to the document "Virtuoso Schematic Editor SKILL Functions Reference". You will find it inside the DFII install hierarchy (../CDSDIR/doc/...)
To create a wire you can use the following command:
 schCreateWire( cv "draw" "full" list(0:0 1:0) 0.0625 0.0625 0.0 )
To create an instance:
 symbolId = dbOpenCellViewByType( "test" "inv1" "symbol" "" 'r )
 instId = schCreateInst( cvId symbolId "I25" 0:0 "R90" )
haikom
View Profile haikomo   IP Logged
