Aug 17th, 2024, 3:21pm
multi-stage PA matching? (Read 2341 times)
email_gz
gaoz.mail@gmail.com
Dec 12th, 2007, 6:24pm
Hello all:
   I have a question about multi-stage PA matching.All cascade amps are lumped parameter devices without transmission line. So should I must design impedance matching net from one inner amp stage to the next inner amp stage ? Also if I don't consider the inner stage impedance matching at all, Would it bring about stability problem?
View Profile email_gz email_gz   IP Logged
Ian
Re: multi-stage PA matching?
Reply #1 - Dec 17th, 2007, 2:33am
For on-chip design, the inter-stage impedance matching is probably not needed, as long as you could get the voltage swing you want. For the stability, it's important to decouple the gate of cascode transistor and supply with big capacitors. Also, take care of the ground bounce for the multi-stage design.
email_gz
gaoz.mail@gmail.com
Reply #2 - Dec 19th, 2007, 5:58pm
Helllo Ian:
   Thanks very much for your significant reply!
