Sep 28th, 2024, 3:19am
PLL frequency hop analysis (Read 2272 times)
keikei
beijing
Dec 17th, 2007, 1:10am
I was confused by some transient simulation results of two PLLs.
The two PLLs,  PLL 1 and PLL 2, of the same bandwidth, based on ring VCO. Initially they operate at frequency f1, and then both hop to f2.  To switch (f2-f1) in frequency, the control voltage of the VCO in PLL 1 varies ⊿V1, while that in PLL 2 is ⊿V2, and ⊿V1<⊿V2.
Someone says since the two have the same bandwidth, PLL 1 and PLL 2 will relock to f2 in the same time.  But it seems that the same bandwidth actually means the  same‘slew rate’of the VCO control voltage.  That is, if ⊿V1<⊿V2, then PLL 1 will relock faster than PLL 2.
What is the problem in this analysis?
Stefan
Re: PLL frequency hop analysis
Reply #1 - Dec 17th, 2007, 4:45am
You're completely right.
Limited Bandwidth = Limited Slewrate
Just think of two identical systems with different initial states.
You wouldn't expect them to lock in the same time, but would expect them (well, first order only) to behave identical.
View Profile 16731287   IP Logged
buddypoor
Bremen, Germany
Reply #2 - Dec 20th, 2007, 9:46am
Hello Keikei,
I am sorry but I really do not understand the problem.
As you describe both PLLs, they are identical, aren´t they ?
