keikei
beijing
Hi, I was confused by some transient simulation results of two PLLs. The two PLLs, PLL 1 and PLL 2, of the same bandwidth, based on ring VCO. Initially they operate at frequency f1, and then both hop to f2. To switch (f2-f1) in frequency, the control voltage of the VCO in PLL 1 varies ⊿V1, while that in PLL 2 is ⊿V2, and ⊿V1<⊿V2. Someone says since the two have the same bandwidth, PLL 1 and PLL 2 will relock to f2 in the same time. But it seems that the same bandwidth actually means the same‘slew rate’of the VCO control voltage. That is, if ⊿V1<⊿V2, then PLL 1 will relock faster than PLL 2. What is the problem in this analysis?
