Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 19
th
, 2024, 4:27am
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› how to run spectre by netlist only
Previous topic
Next topic
how to run spectre by netlist only (Read 2253 times)
jlee
Dec 20
th
, 2007, 8:56pm
Dear all,
How can I run spectre/specreRF simlation by netlist only instead of the traditional way, i.e. capature a schematic, use ADE to generate a netlist and then run simulation?
Jason Lee
IP Logged
rajdeep
UK
Re: how to run spectre by netlist only
Reply #1 -
Dec 20
th
, 2007, 10:02pm
Hi Jason,
It is pretty easy. Just type spectre <netlist.scs> in your terminal. If the path is not set for spectre then you have to give the absolute path for spectre. One easy way to find the exact command that ADE runs when you press RUN+SIMULATION button is to go to the simulation directory (where all your simulation data get dumped) and look for the script runsimulation.
Hope, that helps.
Rajdeep
IP Logged
jlee
Reply #2 -
Dec 20
th
, 2007, 10:18pm
Got it!
Thanks, Rejdeep
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
