Jul 25th, 2024, 5:22pm
Oscillations at DAC output (Read 6185 times)
Dec 26th, 2007, 9:58pm
Hi Guys,
I saw oscillations at the DAC output. Please see my attachment, which is a lab test result of a 10-bit current steering DAC. The output is differential current. Then it is converted using a LM7372 differential amplifier. The clock is 75 MHz crystal oscillator. The die is bonded on the PCB directly. The bonding wire is estimated 2 mm long. I am simulating the DAC with 2nH inductance in series of the DAC output.
Yawei
Re: Oscillations at DAC output
Reply #1 - Feb 8th, 2008, 3:19am
Yawei,
  Just curiuos, were you ever able to debug the oscillation issue?
BTW, you mentioned the modeling the bondwires, did you also model
the rest of the board parasitics, pad capacitance, pad capacitance of
the load resistors, etc?
Reply #2 - Feb 12th, 2008, 6:52pm
Hi Sheldon,
Thank you very much for your comment.
I have no idea about the value of the board parasitics and the pad capacitance of the load resistors. Sad Since the pad adds relative small capacitance only, it is not included in the simulation. The simulation proves that the oscillation caused by the bonding wire attenuates quickly. The oscillation shown in my attachment does not attenuate in fact.
The clock driver is near the DAC output on my evaluation board. I suspect that crosstalk kills the DAC output. However, I have not proved that point.
Or probably that the harmonics of the clock is coupled into the probe. If I have a differential probe, it is easy to eliminate the coupling.
Best regards,
Yawei
« Last Edit: Feb 12th, 2008, 10:37pm by ywguo »
Reply #3 - Feb 19th, 2008, 6:16pm
Yawei,
  Don't know what you have tried, how about the following:
  If you turn off the data, then only the clock would be running and
you could isolate the effect of clock cross-talk from the output
settling and ringing characteristics.
 Also what happens if you change the clock frequency, does the
oscillation change?
If the crosstalk is due to the clock crosstalk, then the frequency
of the clock harmonics should also scale with the clock frequency.
If the oscillation stays the same, then the source of oscillation
may not be clock cross-talk.
